Gear 360 (2017) won't charge/turn on
(Topic created: 08-03-2017 09:51 AM)
user04tBTyvEs2
Gear and Gear Fit
My new Gear 360 arrived yesterday. I installed a memory card, then plugged the camera in with the included USB cable and my Samsung charger. The manual said to let it fully charge, so I left it plugged in overnight. This morning I tried to power up the device, but there is no response whatsoever. No lights, no display, nothing. I know the charger is good because it charges my S7 just fine. The manual isn't very detailed, so I'm not sure what to do. Any suggestions?
JUMP TO SOLUTION
user8Huxd5Cbm5
Gear and Gear Fit
I got my 360 as part of my Note 8 order (discount for Note 7 owners)
useroD5Nzf20QV
Gear and Gear Fit
Thanks, removing the battery and reinserting it worked for me too!
usernusFliWiSj
Gear and Gear Fit
Yup, Mac USB charging  worked for me. I'm Samsung's biggest fan, but Boo!  Samsung, BOO! Get your battery junk figured out!
usernusFliWiSj
Gear and Gear Fit
Mac Usb charger for me. I'm Samsungs biggest fan, but they need to get their battery junk figure it out. Boo Samsung boo!
Maggoto8
Gear and Gear Fit
I tried laptop pc different charger and nothing I guess im calling Samsung tomorrow
userna5UVk1fTX
Gear and Gear Fit
Thanks that worked... But yes would've been great to charge via outlet
user27UXce5p5M
Gear and Gear Fit
Portable charger gets it to start charging
userejmy8kO1xD
Gear and Gear Fit
Same problem here.
user0Ba1JMLwhl
Gear and Gear Fit
Same problem. Wont charge or turn on. So the next thing I tried is removing and reincerting my SD card. Wala...it started charging and working. Hope this doesn't happen ever time I try and use the Gear 360 2017.
Don't know if Samsung can do a firmware update to the unit but seems to be a OS/firmware peoblem.
Samsung;;;you have a problem!
userpXXdwEGMHC
Gear and Gear Fit
Same problem for me. Is there no ffedback from Samsung?
