130 rewards ecertificate
(Topic created: 03-15-2019 06:01 AM)
darsh1
Gear and Gear Fit
Recieved my phone on Tuesday successfully but never received the eCertificate either with phone or in email and the satus for it says Delivered. Does anyone know why it says delivered? Or has anyone seen the same situation in their order satus. If you preodered the phone from samsung.com and added the eCertificate in your cart please guide me through the process on when and how will I get the eCertificate.
JUMP TO SOLUTION
userBAjRnw8ObZ
Gear and Gear Fit
What about the certificate?
user6ZWAJtq9Ql
Gear and Gear Fit
I had this resolved by calling Promotion, who transferred me to ECommerce. The rep attempted to resend the email manually several times, none of which were received at my listed gmail. After the rep suggested using an alternative email, it was discovered that the promotion code had already been sent to my alternative of choice. I'm not sure where that email is listed for Samsung to use it or why it was used instead of the primary email on the account used for the S10+ order, but it may be useful for those who haven't received the code at the expected email address to check their other email accounts just in case.
MoonlightGraham
Gear and Gear Fit
Just wait till you get the eCertificate to discover they changed the T&C of the ecertificate and offer.
I just received mine and it looks like I'll be filing a chargeback if they dont honor ther offer.
Original offer was for buds or $130 ecertificate, I accepted the offer when it was just ecertificate - which was a huge selling point to me because of the stated terms of the ecertificate " any samsung.com or mobile app purchase before 09.01.2019.
My certificate only says it can be used on "mobile accessory" and before July 5th.
NO THANKS.
Offer says they have right to change promo but must be of equal value. Decreasing redemption timeframe and qualifiers is not EQUAL.
Any other ideas to resolve this?
SamsungAdam
Gear and Gear Fit
I would recommend reaching out directly to our E-commerce department at 1-855-726-8721.
user3YNOs9iSuu
Gear and Gear Fit
I received my eCertificate the day after I registeed my purchase using the Shop Samung app.  Unfortunatly they are out of ear buds so I tried to use the eCertificate towards the purchase of the Galaxy Watch.  However the code does not work.  I contact the promotions team via chat in the shop Samsung app and they kept telling me that the watch is not eligible.  However when I read the terms of the eCertificate it clearly states that wearable are eligible with the eCertificate.  I contacted the promotion phone number and they were no help.  My case has supposedly been esclated to some dark hole and could take 2 weeks for a reply.  Hey Samsung, 1. Why would you put a limitation on offer like this when you can't deliver on the promised promotion? 2. You really need to read your own terms for eCertificates and abide by them.  This should not be this hard to have you honor an offer.   After chatting for with 6 different people for over an hour and another 30 mins on the phone.  I'm done.... Samsung GFY
userj7i1Wimgrq
Gear and Gear Fit
I agree with you. I have called twice about the eCertificate and was told that it had been escalated. It definitely should not be that hard to resolves an issue. I also don't understand why Samsung would send out an eCertificate with an invalid code. What is really going on and why would take so long to resolve this issue?
