Highlighted
Anyone else also got a melted/burned gear sport watch charger?
JUMP TO SOLUTION
The charger didn't light up when I was trying to charge, and I found the cord glued on the USB port. This is what it looks like when I tried to pull out the cord...I bought it with in 6 months...
1 SOLUTION
Highlighted
Honored Contributor
Re: Anyone else also got a melted/burned gear sport watch charger?
JUMP TO SOLUTION
Oh no, I hope you are okay? I'd be happy to help with this, please send me a private message with the model code and serial number here: http://bit.ly/2igAXKH
7 REPLIES 7
Highlighted
Honored Contributor
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
As a matter of fact, yes!  I just found mind melted last night when i tried to charge my watch.  Good thing it didn't catch on fire.  Same thing found.
Highlighted
JUMP TO SOLUTION
I am so sorry to hear this! Will you please send a private message with the model code and serial number of the watch? I would like to get some more information from you. http://bit.ly/2XERsky
Highlighted
JUMP TO SOLUTION
Thank you, We have received your email to begin resolving your concerns by setting up an exchange.
Can you also please provide us with the Model code for your Watch, not the charger?
Highlighted
JUMP TO SOLUTION
Yes, I had this happen today!
I was reading the forums to see if this was a known issue and see I am not alone.  I noticed this afternoon that my watch was not charging.  When I went to try a different cable, I noticed it was difficult to pull the cable from the watch charger.  Thatds when I realized it was melted!
Sansung Wireless Charger
model: EP-Y0760
IC: 649E-EPY0760
Watch: Sansung Gear S3
Highlighted
JUMP TO SOLUTION
Hi - Same issue here with the Galaxy Watch charger. Melted/burned last night. Watch wasn't charging. Using factory cable.
Highlighted
Honored Contributor
JUMP TO SOLUTION
Can I have your full model code, serial number, and IMEI number (if LTE) via private message?
