Highlighted
Bixby not updating in Active2
JUMP TO SOLUTION
Hello everybody. Bixby is not updating on my active 2 galaxy watch. It stops after the 0 countdown shows. All apps are perfectly updated except for Bixby. If you'll have a solution please help me thank you very much82EE1BC5-9D66-47DA-9DE5-E9DEE2A133C1.jpeg
1 SOLUTION
Highlighted
Re: Bixby not updating in Active2
JUMP TO SOLUTION
It was updated today but after several installings and this update was late
46 REPLIES 46
Highlighted
JUMP TO SOLUTION
Yea I am having the same exact thing. Tried restarting, connecting to home wifi. Nothing, after the "app permission" confirmation, shows 0% download, then kicks out and back to square one.
Highlighted
JUMP TO SOLUTION
Same problem here...very frustrated
Highlighted
JUMP TO SOLUTION
You need clear stuff off your watch and get space back you have no space left to update Bixby thatscwhat I did and it worked
Highlighted
JUMP TO SOLUTION
You have to remove stuff from your watch. I had the same problem and when I deleted stuff it worked for me and others too!
Highlighted
JUMP TO SOLUTION
Hey, so I got mine to work now.
Back up your data then reset the watch to factory. Bixby works fine now.
Kinda weird because all my apps were "up to date" but after reset I had 6 apps that needed updates. Ironically Bixby was not one of them..... Hopefully that helped!
Highlighted
JUMP TO SOLUTION
This is no solution at all (having to factory reset).
I am having the same problem since two days ago. It suddenlty stopped working and it asking me to update but it won't.
OBVIOUSLY an ISSUE on the SAMSUNG side which they should fix IMMEDIATELY!!
Highlighted
JUMP TO SOLUTION
Your out if space clean it up then Bixby will update
Highlighted
JUMP TO SOLUTION
Utter nonsense...Mine is stuck in an update bixby loop, I only just got the watch this morning how can it be too full?
Highlighted
JUMP TO SOLUTION
Delete data from your watch, it is probably too full then it should work, it did for me.
