Highlighted
Black Screen
I have had my watch for several years and really like it. ABout a week ago I had it on the charger and it got really hot and the screen went black. Now the screen stays black and will not light up. When I put it on the charger it flashes white and will worl as soon as I take it off but as soon as the screen turns off it goes back to just a black screen. The touch controls still work but I can not see anything. Is there a solution or am I going to have to buy a new watch?
1 REPLY 1
Highlighted
Re: Black Screen
Hello!
Are you able to have the screen on long enough to attempt a reset following the steps in this link?
https://www.samsung.com/us/support/answer/ANS00084702/
If a reset was unsuccessful, I would recommend getting your device in the hands of a technician to diagnose and repair your device. I would be happy to look into your service options. Could you please provide me with your model and serial number for your device in a private message? https://bit.ly/2SUXRar
