Highlighted
Blue dot: Gear S3
JUMP TO SOLUTION
Hi, All!
Any one had a problem with a large blue dot (about the size of a dime) on their watch? If it matters,  it's paired to the Note8.
I'll try to include a photo, but the app is acting funky (again), so it may be added later. If you have one in the meantime,  please add.
1 SOLUTION
Highlighted
Re: Blue dot: Gear S3
JUMP TO SOLUTION
My husband closed all running aps. Restarted and disconnectd recnnected and it went away.
15 REPLIES 15
Highlighted
JUMP TO SOLUTION
Hi, my gear 3 is paired to a J3 and i also have the blue dot on my watch that will not go away, any idea on how to do this?
Highlighted
JUMP TO SOLUTION
Hi. I have the gear s3 classic paired ti htc m9+ and it has the same thing! Anyone have any news on this?
Highlighted
JUMP TO SOLUTION
any word on this issue
Highlighted
Honored Contributor
JUMP TO SOLUTION
Just dropping in to thank everyone for discussing this concern!  Let's see if the rest of the Community has any ideas.
Hey Community! Anyone else seeing this problem and have a workaround or suggestion? Let us know!  Smiley Happy
Highlighted
JUMP TO SOLUTION
Close all apps and restart device. Blue dot goes away
Highlighted
JUMP TO SOLUTION
This fixed it for me! Thanks!!
Highlighted
JUMP TO SOLUTION
Power cycle the watch. That is all I know so far...
Highlighted
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
Thanks it worked
