Can I Share Gear S2 Classic?
(Topic created: 08-21-2021 02:09 PM)
requa
Comet
Gear and Gear Fit
I have a Gear S2 Classic watch paired with my Galaxy S21. I would like to be able to let my wife use the watch occasionally paired to her Galaxy S8 with her own profile and data (including her own fitness tracking). I do not intend to connect both phones to the watch at the same time but would like to be able to switch back and forth. Is it possible to share the watch between users?
Dan
Galaxy S21 SM-G991U on Xfinity Mobile + Gear S2 Classic
LongHiker
Samsung Care Ambassador
Gear and Gear Fit
@requa Sorry but not easily. To connect to another phone you would need to reset the phone. So to switch from one phone to another you would need to reset the watch every time you moved it from one phone to the other.
LongHiker
Gear and Gear Fit
requa
Comet
Gear and Gear Fit
Thanks, @LongHiker . I was afraid this was the case but I appreciate the confirmation. At lease I can back up each user's watch profile and restore it if we do swap.
Dan
