Can charger be mounted on wall?
(Topic created: 03-24-2020 08:10 AM)
HeadHunter4621
Gear and Gear Fit
I've been wondering this for a while now: can a gear S3 frontier charger be mounted on a wall somehow? I was wondering this because I saw that when the watch is charging, the gyro is used to tilt the screen.
1 Reply
ddsanchez_82
Product Expert
Gear and Gear Fit
Hey @HeadHunter4621 ,
              While I don't believe that the charger has mounting points I have seen it mounted and charging watch face up.  I assume that they used some kind of double sided adhesive  tape.  While it is possible I ask that you are careful, if not done correctly it may fall and cause damage to the watch.  If this was in anyway helpful please give a like and mark as solved.
                                        Take Care,
                                    ddsanchez_82
