dja2k
Can't register Galaxy Buds bought from Verizon
JUMP TO SOLUTION
I purchased some Galaxy Buds 2 months ago and was trying to register them but the serial # keeps getting rejected online saying its not vaiid.  I purchased them straight from Verizon, though they seem to use some other sticker on the box, not like the retail version you buy in Best Buy, Walmart, etc.  What can I do just to have them registered and monitor warranty status.
1 SOLUTION
Re: Can't register Galaxy Buds bought from Verizon
JUMP TO SOLUTION
Your buds would be considered accessories. We currently do not register accessory devices at this time.
6 REPLIES 6
JUMP TO SOLUTION
The buds are considered an accessory. You will not be able to register them.
dja2k
JUMP TO SOLUTION
Did something change cause why in the past I was able to register my Samsung Level On Pro and Level U Pro wireless headphones?  They show up on Samsung > My Registered Products.
Neutron Star
JUMP TO SOLUTION
When you start using devices/accessories don't they automatically show up under My products on samsung.com?
dja2k
JUMP TO SOLUTION
That's what I thought so too, but I guess not anymore.
Thanks for the replies anyways.
JUMP TO SOLUTION
Samsung Care Ambassador
JUMP TO SOLUTION
@dja2k If you scan the Right Ear buds S/N on the box it should allow you to register the Ear Buds thats how people have been getting them to scan into the system ive done it myself and it works just go to this site and register them https://www.samsung.com/us/support/register/
If the Right doesnt work by scanning enter the numbers manuelly and it should work
Gary-B82-Ambassador-Signature2Note 10+ User on Verizon Wireless
