Changing Weather from Celius to Farenheit
(Topic created: 02-20-2017 08:33 AM)
userv1zLJL1DO6
Gear and Gear Fit
I am using a Samsung Gear S3 Frontier and a Nexus 6P phone.  I can't seem to see how to change the weather data from Celius to Farenheit.  Can someone please let me know how to do this?  Thanks!
JUMP TO SOLUTION
userLIcK98vkb4
Gear and Gear Fit
Thank you!
MythicPink
Gear and Gear Fit
I had the opposite problem and this solution still helped. Thank you.
usergEgPMSr8HR
Gear and Gear Fit
Hi,  I have tried all the instructions as you described but don't work on my frontier gear s3 I see the weather app but give me no options in my phone ZTE 981 need help thanks.
user4MaLgKnJz0
Gear and Gear Fit
You have to use the weather widget that came on the s8 plus,them change the degrees
userKuXaW7sv9C
Gear and Gear Fit
Thank U.
simple: under [Weather]  change the "C" to "F".
Way to go.
user3XUQzoczSn
Gear and Gear Fit
user3XUQzoczSn
Gear and Gear Fit
Please help change weather from Celsius to farenheight
SamsungAdam
Gear and Gear Fit
Just checking back in to see if the troubleshooting I provided was helpful.
SamsungAdam
Gear and Gear Fit
You are very welcome! I am glad it worked for you. 🙂
SamsungAdam
Gear and Gear Fit
Hey, you can try the steps below. Let us know if they solve the issue.
  1. On your primary Home screen, tap Accu weather widget.
  2. Tap the Menu key then select Settings.
  3. Tap General.
  4. Tap Unit.
  5. Depending on your current settings, tap Unit to change from Celsius to Fahrenheit or vice versa. When the dot indicator next the option shows green means the option is selected.
  6. Tap Home button to return to the standby mode.
