Lassitha
Draining battery on galaxy buds
JUMP TO SOLUTION
Recently my buds start to drain the battery. I tested multiple times. It doesn't last more than 3 hrs (with light use). I tested it by keeping them out without connecting to the phone. It kept the charge for about 4-5 hrs.
Also, the case not even last three recharge rounds.  (this started recently, it had 5-6 charge rounds before)  any suggestions?
1 SOLUTION
Re: Draining battery on galaxy buds
JUMP TO SOLUTION
Have you tried resetting the buds?
7 REPLIES 7
JUMP TO SOLUTION
Is the case no longer charging the buds?
Lassitha
JUMP TO SOLUTION
The case is charging the buds, but both the case and buds do not hold the charge.  ( I only used the buds for three months). Before it holds at least five charge rounds from the case. Now it charges only 1 round or little more than 1 round before the case starts to blink red light.
JUMP TO SOLUTION
Lassitha
JUMP TO SOLUTION
yes. I did reset it yesterday. I'm testing now. I will update...
JUMP TO SOLUTION
If the case and buds continue to drain the battery, please send a private message with the model code and serial number. http://bit.ly/2XERsky
Lassitha
JUMP TO SOLUTION
Sorry about the late reply.
Wanted to confirm that, after I reset the buds it did start to work normally. But the charging case still does not hold more than 2-3 charge rounds. I think it will get normal after a few charging cycles.
thank you.
Samsung_d1qbmL1
Even me what happened to me
JUMP TO SOLUTION
