Fit2 Pro: How to set Clock Time format
(Topic created: 04-06-2018 11:18 PM)
OzOracle
Gear and Gear Fit
Hi guys,
I've got Samsung Fit2 Pro which displays the clock in 24 hour format. For example, when it is 7:00 pm, it displays 19:00.
How can I set the Clock Time format to 12 hour format?
Thanks in advance.
cwhaland
Gear and Gear Fit
I have found that many of the watch faces available to download have 12 hour and 24 hour versions.
SamsungMichelle
Red Giant
Gear and Gear Fit
I'd be happy to help. Mind shooting me the full model number of the device?
OzOracle
Gear and Gear Fit
Model: SM-R365
Gear and Gear Fit
Hey, @OzOracle, thanks for clearing that up. You should be able to find this settings in Settings > Device > Date and Time.
Let us know if that helps!
OzOracle
Gear and Gear Fit
I went to "Settings > Device > Date and Time"
I found it disabled.  I cannot tab on it.
userku7l4geQaQ
Gear and Gear Fit
You can use this option only when the Gear is
not connected to a smartphone. Your watch is connected to your phone and use the same format than your phone.
user8IXK5PFUxX
Gear and Gear Fit
This answer is correct.  I just tested it by changing my smartphone time from 12h to 24h.  My watch also changed.
SamsungViv
Honored Contributor
Gear and Gear Fit
@OzOracle
Just checking in to see if you need more assistance.  🙂
cwhaland
Gear and Gear Fit
OzOracle
Gear and Gear Fit
I don't want to change the faces.. I want the default one.
