Highlighted
Forgot the pattern lock on Gear S3
JUMP TO SOLUTION
I forgot the pattern lock for my Gear S3 and tried to put it wrong 13 times. What's the solution to unlock it?
1 SOLUTION
Highlighted
Re: Forgot the pattern lock
JUMP TO SOLUTION
Have you tried resetting your watch? A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, and contacts. It does not delete data stored on the SIM card.
5 REPLIES 5
Highlighted
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
By doing this, will i lose any data on the phone? Or only the watch data will be deleted? (Since you mentioned SIM).
Highlighted
JUMP TO SOLUTION
Just the data on the watch will be deleted.
Highlighted
JUMP TO SOLUTION
Would you please guide me on how to perform the master reset of watch?
Highlighted
JUMP TO SOLUTION
Give these steps a try:
  1. Back up data on the internal memory.
  2. Turn the Galaxy Watch off.
  3. Press and hold the Power key until REBOOTING displays at the bottom of the screen.
  4. Press the Power key three times quickly until the Select REBOOT MODE screen displays.
  5. Press the Power key several times to highlight ' Recovery'.
  6. Press and hold the Home key for three seconds to select, until the Galaxy Watch begins rebooting.
