Frontier s3 wake up gesture not working
(Topic created: 03-02-2019 10:39 AM)
userrmqQsoEnyU
Gear and Gear Fit
I noticed that the wake up gesture has stop working after the update. I need to turn the bezel or push  the button to  see the time of face of my watch
SamsungAdam
Gear and Gear Fit
Give this a try: To restore your watch faces go to Galaxy Apps, All, Gear, you will be able to see you purchased watch faces, download and restore.
SamsungAdam
Gear and Gear Fit
Have you tried unpairing and re-pairing your watch with your device? Have you reset your watch?
userrmqQsoEnyU
Gear and Gear Fit
Can you show me how to do it?
SamsungAdam
Gear and Gear Fit
Give this link a try: http://www.samsung.com/us/support/troubleshooting/TSG01003240/
userrmqQsoEnyU
Gear and Gear Fit
It worked! Thank you! How do I put back my watch face that I previously bought
SamsungAdam
Gear and Gear Fit
userb5EDj91hC9
Gear and Gear Fit
This did not resolve the issue. I've unpaired and repaired. Same issue.
SamsungAdam
Gear and Gear Fit
If you go to the galaxy wearable app and select watch faces, are you able to locate the watch face?
