Galaxy buds series volume is low
(Topic created: 04-27-2019 06:02 PM)
user2C9IYRCqAq
Galaxy Buds
I have galaxy buds 33AA and they were working fine till yesterday. I tried unpairing and pairing them again. Tried increasing the bud volume and it's to the max level. Increased the media volume and nothing ..found one solution online in developers option and diasbled absolute volume sync and still nothing. I don't have audio media sync in the blutooth advance setting so that's not an option. My phone is Galaxy S10+
SamsungAdam
Galaxy Buds
Just to clarify, are you wanting to know if your purchase another Galaxy bud from someone will you be able to pair them?
userIx4zU8bogf
Galaxy Buds
Hi, yes. Would you know if that would be possible?
MrZell
Black Hole
Galaxy Buds
Hey there @userIx4zU8bogf,
Thanks for reaching out, You would need to purchase a new pair.
You can purchase a new pair from https://www.samsung.com
Hope this message finds you well!
^SamsungZell
JOSEPHPATTERSON
Galaxy Buds
Yeah but but paying for a new pair.. sorry
userXojpb8FJye
Galaxy Buds
I have had my Galaxy Buds for 7 days and on the 6th day, the left ear just stop playing sound. I have seen youtube videos mentioning to clean out the ear part, but I have had it for 6 days and that can not be the problem. Plus I do not want to take it apart in case that removes the warranty?
The right bud works fine, no issues. I do not know if it is an update issue, or a speaker issue in the left bud itself. I know the left bud is connected, because the touch works, plus it is read at 100% battery power on the app.
I have tried the 7 sec reset, I have tried completely removing the bluetooth connection and re-adding, I have tried restarting my phone after disconnecting the buds and then re-connecting, I have tried turning on dual audio.
When I use find my airbuds only the right bud beeps, the left does not.
It seems like there is some sort of sound issue, more so than a connection issue in my opinion, but I am no expert, please help.
Kostya
Galaxy Buds
I have a similar issue, a bud is in, but it doesn't respond to tuch, but it's playing music.
userlGWBLttFi3
Galaxy Buds
@userXojpb8FJye
I had a very similar situation, and I now mine is RESOLVED.
In my example, I simply put both buds back in the case and put on charge for about 5 minutes. This seems to have resolved my "no audio" issues for now.
userlha76xiq9D
Galaxy Buds
Can like y’all just do an update to fix this because everything works fine in the left bud except for hearing 😂 like touch is great and on the right one so wassup like frzz i barely had these for 2 months so like can y’all do it ???
usernaFlgivY45
Galaxy Buds
Hi..I have exactly the same thing.  Was working in the morning...on the way home from work..the left ear stopped working....I can play and pause but no sound.  Then after a reset it's now on both
Samsung_Stephanie
Galaxy Buds
And just to confirm, is the software up-to date on both buds?
