TarynClaire
Galaxy Buds - Audio cuts out when phone is in pocket
JUMP TO SOLUTION
I was having an issue with the Galaxy buds where the audio would cut out when I put my phone in my pocket while walking. I'm thinking maybe it was the new update. I've seen other people with this same issue. I just got the buds and when I connected them to my S10+, the app prompted me to download the update. I reset the buds (under "About earbuds" in Galaxy Wearables app) and they seem to be working now when my phone is in my pocket while walking.
1 SOLUTION
TarynClaire
Re: Galaxy Buds - Audio cuts out when phone is in pocket
JUMP TO SOLUTION
I tested them again today after installing the latest S10+ software update this past week, and they seem to work now. I walked the same route as before with my phone in my pocket with no audio issues.
If anyone hasn't downloaded the latest S10+ update yet, try that. I also saw there is an update available for the buds too.
@SteelTSSteel @SamsungRei @SamsungMod23 @SamsungAdam
58 REPLIES 58
TarynClaire
JUMP TO SOLUTION
Ok, nevermind. It works indoors but outside the audio skips a lot. Maybe Bluetooth interference?
JUMP TO SOLUTION
Just to clarify your Galaxy buds are only losing connectivity when the phone is in your pocket is that correct?
TarynClaire
JUMP TO SOLUTION
Hi. Yes that is correct. Only when it's in my pocket outside. Worked just fine indoors. However, would only work if I held the phone in my hand when walking outside.
JUMP TO SOLUTION
Have you tried connecting the Galaxy Buds to any other devices to same if you have the same experience?
Samsung_DPUuOQC
JUMP TO SOLUTION
I'm having this problem but it is with my Samsung s8. Everytime I get put of the car or walk and start to but my phone in my pocket. The audio cuts off and i dont know why. All the software has been updated. Is there a fix for this instead of resetting the headphones?
SteelTSSteel
Cosmic Ray
JUMP TO SOLUTION
@TarynClaire  Having the exact same problem!
One of the most annoying  bugs about the buds.
Did you find a fix?
JHargus
JUMP TO SOLUTION
Having the same issue. Only outdoors and while my phone is in my pocket. Holding my phone fixes the issue. I don't want to hold my phone in my hand while I walk though.
Twiizzy
JUMP TO SOLUTION
The guy up top said he just reset them on the wearables app.
SteelTSSteel
Cosmic Ray
JUMP TO SOLUTION
@Twiizzy Doesn't fix the issue unfortunately .
