userinBzo5B2v0
Galaxy Buds Spotify
JUMP TO SOLUTION
For some reason when i am using spotify the touch controls on the new Galaxy pods do not have any control over the music. (play/pause, next/previous song) Has anyone else had this issue? Is there any solution so i can use the controls with spotify instead of having to pull out my phone to do anything?
Thanks in advance to anyone with insight on this issue!
1 SOLUTION
Nehpets
Re: Galaxy Buds Spotify
JUMP TO SOLUTION
I have noticed that from the start the buds will not control Spotify functions. If I manually hit play/pause when i open Spotify on my phone, then the buds work. Not sure the reason for this though.
3 REPLIES 3
Nehpets
JUMP TO SOLUTION
userinBzo5B2v0
JUMP TO SOLUTION
Thats weird that it does that, but i tried what you said and it worked. Thanks! Hopefully they put out a software update that will fix the problem, but at least this way works for now.
userc6Jf0VJtLo
JUMP TO SOLUTION
This works for now, thanks!
