userjD7nWgtrHe
Galaxy Buds left earbud really quiet
JUMP TO SOLUTION
Hi, I have had these galaxy buds for probably about a month and a half when the left ear bud randomly got really quiet like it was on super low volume. I've done just about every thing I could think of. Checked for updates, reset, charged, connected and disconnected. I'm honestly really disappointed at this point and would REALLY not like to buy a new pair especially if this would happen again. All help appreciated
1 SOLUTION
Re: Galaxy Buds left earbud really quiet
JUMP TO SOLUTION
Can I have your full model code and serial numbers via private message?
30 REPLIES 30
JUMP TO SOLUTION
Hey, give this link a shot.
userKgsKxHrE1B
JUMP TO SOLUTION
Same problem. Link above did not solve the issue. Any other suggestions?
userC7bNzWhT5M
JUMP TO SOLUTION
1. Take the rubber end of that cover the speaker, clean with q tip and alcohol
2. Clean the silver mesh part of the speaker( I took a microfiber cloth and dipped in a capsul of alcohol then wiped with the bud facing down to avoid getting any inside the bud.
3. Wipe the entire body of the bud with a microfiber cloth and alcohol( tshirt or whatever you prefer)
4. Clean the inner and outter part of your ear thoroughly
This worked for me, these buds are sensitive
userR9CpoDxXm7
JUMP TO SOLUTION
Hey im having the same quiet left earbud issue. I checked originally to make sure it was my ear but i tested my right bud as best as i can with my left ear and it sounds fine. However testing my left bud with my right ear resulted in the same quiet audio. I tried the reconnect option, media sync, pretty much everything i could find and so far nothing.
JUMP TO SOLUTION
@userR9CpoDxXm7 Can you send a private message here with your model number and the serial number of the buds?
userjBLqI9OgHH
JUMP TO SOLUTION
I'm having the same issue.
JUMP TO SOLUTION
userX8w8umgcNo
JUMP TO SOLUTION
I am having the same exact problem and no solutions have worked so far
JUMP TO SOLUTION
Hey guys!
Can you send us a private message with the below information here at this link: http://bit.ly/2GH8URL
Model code:
Serial Number:
