Bluestevo
Cosmic Ray
Galaxy Ear Buds
JUMP TO SOLUTION
Just got today. Sadly the sound isn't very loud. If there isn't a fix I'll stick with my LG BT Headset and sell these. Any ideas?
1 SOLUTION
Re: Galaxy Ear Buds
JUMP TO SOLUTION
Try looking for tips and tricks for galaxy buds online or youtube. I've seen this is a common thing but is a simple fix through the app. You have to turn the volume up on the buds themselves to maximum, then you can control the volume from your phone. Just like bluetooth audio works in a car, the car volume won't go loud until your phone is turned up too.
3 REPLIES 3
Re: Galaxy Ear Buds
JUMP TO SOLUTION
Bluestevo
Cosmic Ray
Re: Galaxy Ear Buds
JUMP TO SOLUTION
Have to change touchpad to volume and turn it up directly on the ear buds.
Re: Galaxy Ear Buds
JUMP TO SOLUTION
You must not have the volume adjusted correctly because I never use mine at max volume because I feel that they are too loud.
