Highlighted
Galaxy Fit E keeps vibrating when disconnected from phone
Everytime I walk away from my phone my band vibrates. It is EXTREMELY annoying. I HATE notifications, I want to switch them all off (except when I hit my step target).
Here is the same problem using the Galaxy Wear:
https://us.community.samsung.com/t5/Galaxy-Watch/Annoying-notification-when-not-connected-to-phone/t...
But the solution there requires changing the watch's settings, the galaxy fit device does not have its own settings you can change.
So, how can I disable the vibration when I walk out of range of my phone?
4 REPLIES 4
Highlighted
Re: Galaxy Fit E keeps vibrating when disconnected from phone
Fully subscribe to this. When I turn vibrations off, all souls be off. I also want to set when I het vibrations or not. Please fix ASAP.
Highlighted
Your device is probably paired with your computer or other equipment. This happened with my bracelet, I disabled pairing with the notebook and solved it.
Highlighted
Same here. I have turned off all notifications and it is still vibrating each time I am in and then go out of range. As someone who does not carry his phone around with him everywhere this is truly annoying. Please reply Samsung and please fix this.
Highlighted
@userff25vanydb there is no solution. I sold my Fit E and bought a Mii Band intead which does not have this problem.
