Galaxy Fit won't turn on
(Topic created: 10-20-2019 10:34 AM)
Samsung_fD2Jv2S
Gear and Gear Fit
Put my Galaxy Fit on the charger last night, all was well. This morning even was black. Have tried pressing the button, holding the button for 7 seconds, on charger, off charger, unpaired, re-paired, uninstalled, re- installed, nothing works. Every once in a while the screen will flash the white Samsung Galaxy logo on the screen then nothing. I've only had it a few weeks.
SamsungQue
Honored Contributor
Gear and Gear Fit
I would recommend giving this troubleshooting article a try: http://www.samsung.com/us/support/troubleshooting/TSG01003100/
If the troubleshooting steps have not helped a service evaluation and possibly repair would be recommended. Can you send me a private message using this link here so that I can look into what options you have available? Provide the following information
  • Model Number
  • Serial Number
Ruggy
Gear and Gear Fit
it worked!
SamsungQue
Honored Contributor
Gear and Gear Fit
  • Model Number
  • Serial Number
