userwoxflxstDy
Galaxy S8 plus will not connect to Gear S3
My S8 plus will not connect to my Gears S3. I have uninstalled and reinstalled the Galaxy Wear app, cleared the cache, and restarted both devices. The phone sees the S3 but will not connect.
5 REPLIES 5
Re: Galaxy S8 plus will not connect to Gear S3
userwoxflxstDy
I have tried that over and over again and it doesn't work.
Thank you for confirming. Please send a private message with the full model code and serial number of the watch. Is the watch connected through Bluetooth only? http://bit.ly/2XERsky
Samsung_EsLGofl
I'm having the same problem with my Galaxy S9+. I've clea...
I'm having the same problem with my Galaxy S9+. I've cleared the cache. I've connected via bluetooth and tapping the app on the phone, which will show "connecting" but never connects.
Appreciate any suggestions
userwoxflxstDy
Mine ended up being an internal battery failure and bluetooth failure. I had to send it in to be repaired.
