userZUNLwok1lv
Galaxy buds charging case lost?
How do I get a replacement for the Galaxy buds case. I still have both earbuds. I just need the charging case.
5 REPLIES 5
Samsung Care Ambassador
Re: Galaxy buds charging case lost?
@userZUNLwok1lv I would suggest contacting the Samsung E-Commerce Support Department they should be able to help you can use the information provided belo
18557268721
https://www.samsung.com/us/support/contact-customer-services/
P.s I've seen some aftermarket chargers being listed on Amazon.com
Gary-B82-Ambassador-Signature2Note 10+ User on Verizon Wireless
Hey there!
@userZUNLwok1lv
We do not offer the option of purchasing just the case by itself. You would need to purchase a new set of buds.
userLLvbOTB190
Is this a joke? How can't you buy a new one?
@userLLvbOTB190 as I've said above
I would suggest contacting the Samsung E-Commerce Support Department they should be able to help you can use the information provided below
18557268721
userukgRoGoTb2
They can't help you. I've talked to the ecommerce department, Support, and Parts with no solution offered.
