Highlighted
Gear 2Fit Pro Overheat
JUMP TO SOLUTION
I've had my Gear 2Fit Pro for just over a year now without major issues. Recently the watch started to overheat in the vicinity of the heart rate monitor, to the extent that I had to take it off. The watch then switches off on its own. It seems like a battery problem.
I have tried multiple reboots, checked that the lastest software update was installed and even reset the watch. None of the aforementioned resolved the issue.
Any tips or advice to fix this?
1 SOLUTION
Highlighted
Honored Contributor
Re: Gear 2Fit Pro Overheat
JUMP TO SOLUTION
Can I have your full model code, serial number, and IMEI number (if LTE) via private message?
33 REPLIES 33
Highlighted
JUMP TO SOLUTION
Hello there @userSBbofKr1al, would you mind sending us a private message here with your full model code and serial number for the watch.
Highlighted
JUMP TO SOLUTION
Would love the solution posted as it is happening to me as well.
Highlighted
JUMP TO SOLUTION
I have the same thing happening started 2 weeks ago.
Highlighted
JUMP TO SOLUTION
@user9jeIZo3ROF Can you please send a PM here with your full model and serial number?
Highlighted
JUMP TO SOLUTION
Same Issue HERE!
Just started today! My Gear Fir2 Pro is not even six month old.
Highlighted
JUMP TO SOLUTION
@userDpJY8eHqJK Can I please have your full model number and serial number in a private message: http://bit.ly/2JH2rq2
Highlighted
JUMP TO SOLUTION
I'm currently having the same issue would love some help
Highlighted
JUMP TO SOLUTION
Good morning @userTipBv7CVmx, will you please send a private message with your full model code and serial number? http://bit.ly/2Kq3B5F
Highlighted
JUMP TO SOLUTION
My gear fit 2 pro keeps overheating and then after a few seconds it turns off, what can i do? pls help me asap
