userv9ptlf16iW
Gear 2Fit overheat
I have had mine since February and today it start with a white screen. Put it to charge and it was doing the same thing and after that it start overheating. Now is just a black screen but it still get notifications. Please help
1 REPLY 1
Re: Gear 2Fit overheat
Hey there!
I would be happy to look into your concerns.
I would recommend giving this troubleshooting article a try: http://www.samsung.com/us/support/troubleshooting/TSG01003181/
