Highlighted
Gear Fit 2 Pro Overheating
Got my wife the Gear Fit 2 Pro for Christmas and it just started getting hot....REAL hot, while sitting on her charger.  Now, it won't turn on or charge, but still gets hot if placed on charger.
2 REPLIES 2
Highlighted
Re: Gear Fit 2 Pro Overheating
Thanks for reaching out! Does it only become hot while on the charger? Are you still using the original charger that came with the watch? Please send a private message with the model code and serial number or IMEI number of the watch so I may look into this further. http://bit.ly/2XERsky
Highlighted
Did you get my response to this yesterday with all the info you needed to open a service ticket???
Thank you,
Nicholas
