- Mute
10-25-2021 08:53 AM in
Gear and Gear FitI've had my Gear Fit 2 Pro for a few years now.
I've recently started swimming 3 times a week in a swimming pool.
The watch is advertised as water proof, and has an app for swimming.
First two sessions it worked just fine, but after the 3rd session I noticed, it started doing something weird - randomly turning itself off, even when charged.
It's really weird - I would turn the watch on, and it would stay on/working for a while (sometimes it would be 20 - 30 minutes, other time it would be 1 - 2 hours of working just fine), only to at some point go completely offline on its own, without showing any error or anything.
I wonder if anyone encountered this problem after swimming (just regular laps in a swimming pool, swimming front crawl only) ?
Solved! Go to Solution.
- Mute
10-30-2021 09:58 AM (Last edited 01-19-2023 11:10 AM ) in
Gear and Gear FitHello, We understand how frustrating it is when your watch is randomly turning itself off. You can try resetting the watch to see if that stops the watch from powering off. https://www.samsung.com/us/support/answer/ANS00084702/
If the watch continues to power off, we recommend taking a look at the newest Samsung Watches available, as the Gear Fit 2 Pro has reached the end of support. https://www.samsung.com/us/watches/
- Mute
