userG3Jy1IegwX
Re: Gear Fit 2 Quick Messages
JUMP TO SOLUTION
Did the trick. Thanks
userJPMTZDd4by
JUMP TO SOLUTION
Textra is fixed my problem in sms.but same issue in whatsup and skype
userWt9xF6riZd
JUMP TO SOLUTION
This helped me; thank you!  Galaxy S7 on Verizon and I use Messages+, but allowing Samsung "messages" worked just fine to be able to reply quick text.
userPhQSygQNW9
JUMP TO SOLUTION
this worked for me, turning off Messaging from Verizon and google Wear os on watch, leaving only "Messages"  TY!
JUMP TO SOLUTION
@userPhQSygQN; Thank you for letting us know what worked for you!
user6bln6hALS7
JUMP TO SOLUTION
I am having the same problem. Please help. Android wear app cannot seem to locate or pair to my gf2 pro. Using a Sony Xperia xa1. Everything else works fine. Just can't reply to msgs. It says check phone.  Really frustrating.
