Parisphy
- Mute
06-07-2021 04:32 AM in
Gear and Gear Fit- My Gear Fit 2 started to over heat within seconds of being placed upon the charger...now the screen is completely black and will not power on
Solved! Go to Solution.
1 Reply
- Mute
06-07-2021 07:43 AM (Last edited 3 weeks ago ) in
Gear and Gear FitThank you for reaching out. Regretfully based on the date of production the device has reached end of life status. This means that any repairs would be beyond economical repair, and it is recommended to seek other options with your retailer or carrier.
Opens in new window
PDF Download
Word Download
Excel Download
PowerPoint Download
Document Download
