- Mute
07-26-2016 09:31 AM (Last edited 07-28-2017 02:26 PM by SamsungViv ) in
Gear and Gear FitI am using the "Digital" watch face on my Gear Fit 2 with the weather displayed at the bottom of the screen. The weather does not update on its own. I have to tap on the weather to open it up and then wait for it to update. Should the weather on the watch face be automatically updating?
Solved! Go to Solution.
- Mute
11-01-2016 08:56 PM in
Gear and Gear FitJeepers! Finally figured it out. Very disappointed that Samsung can't tell us how to configure their own device and all the repeated nonsense about third party apps and vendors and watch faces! It's a built in app, a built in watch face and Samsung support should know this and be able to help its users configure the thing!
Anyway, rant over. Here is how you configure the weather app (I don't remember seeing this the last 4 or 5 times I tried to find how to set this, so maybe it was released in an update to the Gear app):
On your phone, launch Samsung Gear, then:
Watch Faces > Digital > Stylise > Complication > Weather.
Now you will see a "Settings" button next to the picture of the watch face, select this and configure your weather options!!
Options include "Unit", "Auto refresh" and "Use current location"
Phew.
- Mute
07-27-2016 01:29 PM in
Gear and Gear FitAlso, is ther a way to set the AccuWeather app to show temperature in Celsius?
- Mute
04-14-2017 06:12 AM in
Gear and Gear FitYou need install the new Samsung Weather in Gear Fit. Go in Samsung Galaxy App for Gear, in Gear App located in cellphone, go in setup, App layout and locate the Weather App, click on a gear just in right side and setup popup will open. You will can select more options about The Weather App in Gear Fit 2.
- Mute
04-14-2017 06:41 AM in
Gear and Gear FitThanks. I had it working on my watchface but that allows you to swipe right to access the weather if you were using a watchface that did not support the weather complication. It also updated the weather screen with a slightly different layout including sunset, chance of rain, uv index. If you go into Apps Layout in the Gear Fit 2 app, there's a gear icon to set the temperature units, refresh rate, etc.
- Mute
08-04-2017 06:30 AM in
Gear and Gear FitThat fixed mine. Thank you!
- Mute
08-06-2016 12:19 PM in
Gear and Gear FitMine does this as well...it really pisses me off. Why even display the weather if it isn't current? Grrr...
- Mute
08-08-2016 01:19 PM in
Gear and Gear FitHi, everyone. We are so glad to have you here and are happy to see your active participation. We do recommend that you include a little more information regarding your question. This might include the model number of your watch, the device you have your phone connected to, and the current software version of your Gear Fit 2. Please also include information on the watchface you are using to view the weather on. For setting the temperature settings, you may go into your gear manager and select the accuweather app for additional options that may be available.
- Mute
08-08-2016 06:56 PM (Last edited 08-08-2016 06:57 PM ) in
Gear and Gear Fit
Come on, really? His question seemed pretty clear...but your answer shows you do not know the product you are trying to assist with.
What he is asking is whether the weather displayed on watch faces should automatically update the tempature or if we are suppose to update the tempature by opening the hidden accuweather app. In my experience, the CURRENT tempature can only be displayed by opening the hidden accuweather app via a watch face and letting it update. What I'm saying is , the tempature displayed on watch face(regardless of what face) is NOT the current temp, it is the temp at the time of the last update...Updates ONLY happen by opening the accuweather app. This is so stupid; it should be updating the weather on a regular basis on its own!
Now comes your comments on using the gear manager to access accuweather's additional options....simply not possible on a GearFit 2 with the latest software. You obviously don't know the products you are troubleshooting. Grrr...
- Mute
08-08-2016 07:16 PM in
Gear and Gear FitModel number SM-R360
Software version R360XXU1BP3
Phone LG Nexus 5X
- Mute
08-12-2016 09:58 AM in
Gear and Gear FitThank you for providing us that information. We do ask that you provide us with more information on this watch face. We do believe it to be a third party watch face and would recommend reaching out to the developer of this watch face for more information regarding your inquiry. Samsung does not guarantee compatibility with third party applications. You may find their information in the play store or galaxy apps store under developer information.
