Gear Fit Pro 2 Overheating and Powering off
(Topic created: 03-17-2021 02:43 PM)
userFNSX1FP81J
Gear and Gear Fit
My gear fit 2 pro has been powering off immediately after the screen goes in stand by mode.  Recently, it had been hot to touch on the sensor after rebooting.  I have already performed a factory reset by pressing pressing button and by going into the settings->gear info->reset gear.  Nothing is working.  Thanks in advance.
SamsungJoJo
Gear and Gear Fit
Hello,
I will be happy to look further into this for you.
Can you send a private message providing the full model code and the serial number so I can further assist? Sounds like your watch may need a service repair. http://bit.ly/2GGYul4
SamsungJoJo
Gear and Gear Fit
Hello,
SamsungJoJo
Gear and Gear Fit
An Accepted Solution has been marked and provided for this thread. This thread will be locked for further replies. In hopes to keep the integrity of the thread from steering in a non-technical manner. If you have a separate concern, feel free to post again or send one of our moderators a private message with more details. Please note duplicate posts on similar subjects starting 2/1/21, will be removed to keep our community organized and make it easier for our users to find needed content. Remember that if you do make a post, that you include as many details about your symptoms as possible. Also, make sure that your title is a good summary of the overall situation that's occurring. Thank you for being part of the Community!
