Gear Fit Pro 2 Won't boot up?
(Topic created: 08-18-2021 09:45 PM)
useresoc8gygsP
Gear and Gear Fit
I've had the Gear Fit Pro 2 for maybe 3 or 4 years with almost no problems. About a week or so ago, I left the watch run without being on the charger.  Later when I wanted to use it, it was completely dead.  Tried to charge it for a couple of days without success. I would get a momentary "lightning bolt" and then it would disappear.
I was about to toss it, but thought I would give it one more trip.  Back on the charger, but this time I held it very firmly in the charger position and the weak lightning bolt remained dimly on.  After about 10 minutes I released the pressure that I was applying and the lightning bolt stayed on.  I let it continue to charge for about 30 more minutes and it was either 100% charged or close to it.
Sometimes these rechargeable batteries are hard to get going until they get to at lease 1-2% and then they recharge fine. So instead of my  Gear in the waste backet, it's like it was new.  So  don't give up!
TheGalaxy
Neutron Star
Gear and Gear Fit
Thanks for sharing
user1jj6nzObvO
Gear and Gear Fit
Having same problem with my gear 3
