Gear Fit2 Pro Overheat
(Topic created: 07-03-2020 04:26 AM)
user8BY8mgc6mS
Gear and Gear Fit
Gear Fit2 Pro shuts itself off. I have reset the watch and it still does this. The watch had 80% battery left and suddenly started shutting down after only being turned on for about a minute. When turning the watch on the screen glitches and flashes solid white and shows no battery left. When I try to charge the watch, I get an error notice that the battery will not charge because it's too hot. Then the screen changes to a flashing triangle with a red thermometer. I left the watch off overnight to allow it to cool. When I attempted to  charge it or turn it on the next morning, I immediately had the same issues.
SamsungAdam
Gear and Gear Fit
Thank you for reaching out.  I would recommend a service repair. Can you please provide me with the following information in a private message: http://bit.ly/2JH2rq2
Full Name:
Street address:
Email Address:
Best Contact Number:
Alternate Telephone Number: (If Available)
Model Code:
Serial/IMEI Number:
SamsungAdam
Gear and Gear Fit
Full Name:
Street address:
Email Address:
Model Code:
Serial/IMEI Number:
Geno71
Samsung Care Ambassador
Gear and Gear Fit
Hi @user8BY8mgc6mS
It sounds like the battery is bad. You can try factory resetting the device to see if it was software related, but it's likely a hardware issue and the device might need to be repaired if possible or replaced.
user8FN4c7Vl9O
Gear and Gear Fit
Did a reset, a factory reset( with the few seconds before if shutsdown) but still no luck. Why is there a battery issue just over 1 year of use? Very, very disappointed with Samsung!!
userkGRDX49CVe
Gear and Gear Fit
I'm having the same issue.  Yesterday it kept turning off by itself, I'd turn it on, and within a minute it would turn itself back off.  Tried charging yesterday and today and it says the battery needs to cool.  What do I need to do?
