userAa2K1RVDpZ
Gear IconX problem with proximity sensor
My earphones usually beeping while in my ears. Latest update installed. I tried to reset my earphones but it didn't help. In the middle of a call my earphones stop working.
2 REPLIES 2
Arkkuss
Re: Gear IconX problem with proximity sensor
I'm having the same problem.  If I turn my head fast or look down the left one chimes and stops whatever I'm listening to.  Takes very little to cause it.  I've had them since last summer and for the first few months they worked well but by this spring they were problematic.  The case no longer latches, I have to put a rubber band around it to get them to charge.  Actually, the right one still works well if I use just it.  It's the left one that a constant aggravation.
userAa2K1RVDpZ
Samsung?
Samsung?
