Lokione
Cosmic Ray
Gear S not connecting to Gear Manager
JUMP TO SOLUTION
I have a Gear S and It can't connect to Gear Manager on S7E.
1 SOLUTION
Honored Contributor
Re: Gear S not connecting to Gear Manager
JUMP TO SOLUTION
Hello there, @Lokione
Let's try some troubleshooting steps, just let us know how these go!
  1. Are all your Apps are up to date? You have 2 places that you need to look. Google Play store and Galaxy app store. Go to both and check My Apps. Make sure there is no app that needs updating.
  2. Is your phone OS up to date? Go to Settings, About phone and check for software update. Make sure you have the latest phone software.
  3. Clear phone cache. Instructions are here
  4. Clear Application cache and sometimes Application data. Instructions are here
  5. You may also want to delete the Gear Manager app and then re-download it to try again.
17 REPLIES 17
Honored Contributor
JUMP TO SOLUTION
Lokione
Cosmic Ray
JUMP TO SOLUTION
Thanks, it works again
Honored Contributor
JUMP TO SOLUTION
Anytime! Glad to hear things are better.  Smiley Happy
userxAHKdVb2RI
JUMP TO SOLUTION
This solution did not help me. I have a J5 and a gear S. Can you help me please.
userKUSf0Qpoh7
JUMP TO SOLUTION
J7 Pro  does not connect to gear s
JUMP TO SOLUTION
What app are you using to try to connect the gear s to your device?
userKUSf0Qpoh7
JUMP TO SOLUTION
Gear manager from play store
JUMP TO SOLUTION
Is there an error message you are receiving?
userKUSf0Qpoh7
JUMP TO SOLUTION
Yes phone not compatible
