Re: Gear S not connecting to Gear Manager
JUMP TO SOLUTION
What version of Android is currently on your device? Also, could I please get your full model number?
userKUSf0Qpoh7
JUMP TO SOLUTION
Andriod oreo 8  Samsung Galaxy J7 Pro  2017
JUMP TO SOLUTION
Can I please get your full model number and IMEI in a private message?
userIQ01Of5LE5
JUMP TO SOLUTION
Hi there,
This solution did not work for me.
I have tried downloading one, multiple, and all of the plug-ins.
I've tried restarting both devices multiple times.
I've tried deleting the app multiple times.
I have exhausted every resource I can find.
I have a gear 2 neo, and a pixel. When I open the gear manager app, it is unable to find my watch.
It does connect via Bluetooth, but the gear manager will not show the device.
Please help.
Thank you.
JUMP TO SOLUTION
@userIQ01Of5LE5 are you getting any error messages?
JUMP TO SOLUTION
My Gear S is also not connecting to Gear Manager on my S7 Edge. Bluetooth and the app sees it just fine but when I go to connect both on the watch and the app it keeps failing. I have emptied the cache in Galaxy Wearable and made certain all of apps are up to date. I have also tried uninstalling Gear Wearable and re-installing. It connects fine to my S3 watch and my earbuds but not to my original Gear S. However, it connects immediately and fine to my old Note 3. Recos?
JUMP TO SOLUTION
Have you made sure that your Galaxy Wearables application is fully up to date as well as all the plugins?
usermvXrnyqHtc
JUMP TO SOLUTION
The Gear manager in play store do not work for gear s.
