Highlighted
Gear S2 watch overheats and drains battery suddenly
JUMP TO SOLUTION
I purchased S2 Gear for my wife last October 2019. It worked great until 2 days ago.  No battery charge. Somehow it worked when I made the battery charger unplugged and plugged with S2. It changed 100%, so my wife wore it on her wrist,  but my wife felt the heat from S2, and its battery drained in a couple minutes to 0%.
Currently Wife's S2 does not work. Inform me how to replace the watch with the new if Samsung can't repair it?
Thank you,
Peter Park
1 SOLUTION
Highlighted
Re: Gear S2 watch overheats and drains battery suddenly
JUMP TO SOLUTION
Thank you for reaching out! I will be happy to look into your repair options. Please send a private message with the full model code and the serial number. http://bit.ly/2XERsky
1 REPLY 1
Highlighted
JUMP TO SOLUTION
