Gear S2 will not connect with Galaxy S21
(Topic created: 04-24-2021 08:16 AM)
Kilo234
Gear and Gear Fit
When I try to connect my Gear 2 to my Galaxy S21 It says "unable to install, unexpected error" please help.
SamsungAdam
Gear and Gear Fit
Hello, Based on the information from product support due to the Galaxy Gear S2 being end of life, it is no longer compatible with the wearables application. If you have had this watch for sometime, you should have noticed a message that was sent to you regarding this specifically. At this time we would recommend updating to one of the later watch models in order to get the best watch experience.
SamsungAdam
Gear and Gear Fit
SamsungAdam
Gear and Gear Fit
An Accepted Solution has been marked, and provided for this thread. The thread will now be locked for further replies. in hopes to keep the integrity of the thread from steering in a non-technical manner. We understand the solution marked may not be a solution for everyone, If you have a separate concern or question, feel free to Private message a moderator or post a new thread with additional details. Please note duplicate posts on similar subjects starting 2/1/21, will be removed in order to keep our community organized and make it easier for our users to find needed content. Remember that if you do make a new post, please include as many details about your symptoms as possible. Also, make sure that your title is a good summary of the overall situation that's occurring. Thank you for being part of the community!
