- Mute
‎04-16-2021 09:40 AM in
Gear and Gear FitI just bought a Gear S3 classic from amazon refurbished, I charged it up and turned it on only to find that the battery doesn't hold it's charge for more than an hour. Not only that but when it's dead and won't charge on again, I put it on the charger and it shows as 70% for some reason despite not being able to turn on.
Solved! Go to Solution.
- Mute
‎04-21-2021
10:01 AM
(Last edited
‎08-05-2022
07:44 AM
by
SamsungAdam
) in
Thank you for reaching out. Regretfully based on the date of production the device has reached end of life status. This means that any repairs would be beyond economical repair, and it is recommended to seek other options with your retailer or carrier.
- Mute
‎04-21-2021
10:01 AM
(Last edited
‎08-05-2022
07:44 AM
by
SamsungAdam
) in
