Gear S3 Frontier Skin Irritation
(Topic created: 02-17-2019 05:13 PM)
userHhF3fe58ig
Gear and Gear Fit
my  GS3 frontier is causing skin irritation right on the sides of the wrists to the point where my skin will peel off and leaves red irritation marks.
if u have any information on this i would appreciate it
SamsungLarryK
Gear and Gear Fit
Can I have your full model code, serial number, and IMEI number via private message?
SamsungLarryK
Gear and Gear Fit
userVN9WHlhWKN
Gear and Gear Fit
I'm litterally having the same issue, was there a solution? I'm assuming change the band?
Savagedonbihhh
Cosmic Ray
Gear and Gear Fit
Buy soft silicone band and also moisturize your wrist. That what worked for me to be honest
SapperBill
Gear and Gear Fit
I bought different bands that are breathable and I never had an issue after I switched them out.
SapperBill
Gear and Gear Fit
Seinit Soft Silicone Sport Band 22mm Replacement Strap Compatible with Samsung Galaxy Watch (46mm), Gear S3 Frontier, Classic Smart Watch, 8-Pack https://www.amazon.com/dp/B07QKQGPJ6/ref=cm_sw_r_cp_apa_i_JlW8DbVN9XZQF
