Gear S3 Frontier and iPhone: missing notifications
(Topic created: 02-07-2018 10:39 AM)
userNGT55OgDpi
Gear and Gear Fit
I have a Gear S3 Frontier paired with an iPhone 7 running iOS 11.2.5.
Unfortunately, not all notifications seem to find their way to the watch. Some of them do (for instance calendar notifications, or notification from my local commutter app), others don't (for instance Whatsapp or texts).
I cannot see any configuration difference on the phone between the applications which work and those which don't: their notification settings seem to be the same.
Needless to say that I don't have blocked any application on the watch.
Any hint ? What are the notification setting needed on the iPhone to make sure a notification is forwarded on the watch ?
Thanks for your help.
PS: This new message form doesn't take "Gear S3" as a label ...
userNGT55OgDpi
Gear and Gear Fit
I finally found the solution. To receive notifications, the "Show in History" setting needs to be "On" in "Settings"/"Notifications"/App Name on the Phone.
As a side note, the watch doesn't honor the "Show Preview" settings : previews are always displayed on the watch.
Gear and Gear Fit
from the gear manager, did you turn all on the notification?
userNGT55OgDpi
Gear and Gear Fit
Yes, I did.
userNGT55OgDpi
Gear and Gear Fit
userswdK02YCXO
Gear and Gear Fit
Hi, i just got this smartwatch and a day after i bought the notifications are not showing, i have to turn off BT and turn it back on in order to get the messages on the watch. after that, it just doesnt show anymore again. its super frustrating. i have all notifications showing on the phone app so i just dont understand whats going on. any help?
SamsungLarryK
Gear and Gear Fit
Is your unit up to date?
userFfoK1LaGTa
Gear and Gear Fit
Got it last night. All notifications are showing up except messaging. I tried all above steps and everything is up to date. Any ideas?
usermDzvrsalmM
Gear and Gear Fit
in the same boat. Got Gear 3 last night, paired with Iphone 5, running on iOS 11. All notifications are there, but texts are not coming through.  If that cant be done, this watch is useless to me
usermQgzt1N1XF
Gear and Gear Fit
Even I am facing the same on my android(oneplus5)
user1F669FvQzo
Gear and Gear Fit
I think I posted this in the wrong thread before, so I’m posting it here.
I have found /A/ solution for the iOS NOTIFICATION issue only. This may not work for everyone but it worked for me:
Go into Settings>Notifications>Messages and ensure everything is set to the following (because I’m not sure which change made it work):
Allow notifications: on
Alerts: Notification center
Banner style: Temporary
Sounds: *your sound*
Badges: On
Show previews: When unlocked
Notification grouping: By app
i think the last one is the most important.
