- Mute
- Email to a Friend
05-20-2019 10:15 AM in
Gear and Gear FitLove the new look of the Gear S3 Frontier now that it has One UI go install if you haven't already
If you've found my post to be helpful, please like the post. If my response resolved your issue, please press the "✓ Accept as Solution" button.
Solved! Go to Solution.
- Mute
- Email to a Friend
05-20-2019 03:22 PM in
Gear and Gear Fit- Mark as New
- Mute
- Email to a Friend
05-20-2019 03:11 PM in
Gear and Gear FitAny idea where to find the new watch faces that were promised?
- Mute
- Email to a Friend
- Mute
- Email to a Friend
05-21-2019 01:21 AM in
Gear and Gear FitDo you know if the gear s3 classic will be getting the one ui update as well?
- Mute
- Email to a Friend
05-21-2019 08:26 AM in
Gear and Gear FitThis update broke my s3 frontier.
I was getting 2 days of battery life with AOD on and a custom watch face.
After this update I get 4 hours max. Uninstalled all 3rd party apps/watch faces. Turned off all potentially battery draining options/sensors. Factory reset. Airplane mode.
Nothing helps.
Watch is worthless now.
- Mute
- Email to a Friend
05-21-2019 01:36 PM in
Gear and Gear FitDitto for me.
- Mute
- Email to a Friend
05-21-2019 08:44 AM in
Gear and Gear FitWish my Gear 3 Frontier would get the update.
