Gear S3 Frontier will not power on
(Topic created: 08-24-2020 09:49 AM)
uservMEIFufNy3
Gear and Gear Fit
My Samsung Gear S3 Frontier watch will not turn on.  The watch will charge and I have fully charged it then tried the following;
1.  I have held the power button down for 2 minutes with no result.
2. I have put the watch on the charging stand and held the power button down for about 2 minutes with no result.
3. I have also tried to hold both keys down for 2 minutes with no result.
SamsungAdam
Gear and Gear Fit
If your watch's battery is completely discharged, it will not power on. You'll need to charge it before turning it on. If the watch will not power on or if it doesn't seem to charge, the problem could be anything from the battery, connection, the charger, or the watch itself. Give this link a try: https://www.samsung.com/us/support/troubleshooting/TSG01003100/
If you try the troubleshooting provided and are still experiencing these symptoms, I would recommend a service repair. Can you please provide me with the following information in a private message: http://bit.ly/2JH2rq2
Full Name:
Street address:
Email Address:
Best Contact Number:
Alternate Telephone Number: (If Available)
Model Code:
Serial/IMEI Number:
SamsungAdam
Gear and Gear Fit
Full Name:
Street address:
Email Address:
Model Code:
Serial/IMEI Number:
user0qdcUsgq34
Gear and Gear Fit
Did you try using both buttons? I know mine did that were it wouldnt turn on unless I press both buttons even though my on/off button doesn't work for any other funtion
