Highlighted
Gear S3 Touchscreen is not responding
Today my Gear S3 touchscreen is non-responsive - no water, no damage, no clue why.
With alarms set to go off in the early AM, it is inconvenient to say the least to not be able to turn them off. Please help.
Thanks.
3 REPLIES 3
Highlighted
Re: Gear S3 Touchscreen is not responding
Thank you for reaching out! Have you tried all of the steps here? https://www.samsung.com/us/support/troubleshooting/TSG01003105/
Highlighted
Yes, I had tried those things previously and just now tried them again.
i cannot Tap the Power Off button as the touchscreen is not functioning, but if I hold the buttons in, the watch will go through a rebooting sequence.
I rebooted my phone (don't know why this should be) and I double checked to make sure the watch had the latest software installed on it - it does.
The touchscreen is still not functioning.
Highlighted
It may need to be evaluated by a certified technician. Will you please send a private message with the model code and serial number so I may look into this further? http://bit.ly/2XERsky
