CaptianB
Gear S3 battery dies but when put on charger battery says almost full
hello,
pls forgive if this is a duplicate post. I am new to this forum and I cannot seem to find anyone else with my particular issue. I will charge my watch for a full day. after taken off the charger, it will hit about 50% in about 30 min. it will completely die in about 1 hr. I’ll take it off and put it on the charger only for the watch to then ready out something like 85% charged. I have reset this thing like 5 times. even going through the factory reset through the watch itself. done all the updates and still the same thing.
has anyone else experienced something like this?
if so, what was the fix for you?
any help is appreciated. thx!
1 REPLY 1
userZDZ19eI3BA
Re: Gear S3 battery dies but when put on charger battery says almost full
There is a string for this. They know of the issue. here is the link. https://us.community.samsung.com/t5/Gear-and-Gear-Fit/Gear-S3-randomly-turns-off-and-wont-turn-back-...
Good luck
