Gear S3 battery loss
(Topic created: 04-24-2021 06:30 AM)
usermvqscUwY5E
Gear and Gear Fit
My Samsung watch used to hold 2d battery time. Since 2021 April 21, my watch lasts for only about 8 hours. This is following Samsung updates and app updates. I am not using differently and no new apps.
Samsung HELP!
LeonRH
Cosmic Ray
Gear and Gear Fit
I had that problem a while ago. I reset the watch and it fixed it. I now get 1 1/2 to 2 days. Back it up first.
LeonRH
Cosmic Ray
Gear and Gear Fit
usermvqscUwY5E
Gear and Gear Fit
Thanks Leon. Good tip.
userXoP0gXuB0H
Gear and Gear Fit
How do you reset the watch?
LeonRH
Cosmic Ray
Gear and Gear Fit
