- Mute
- Email to a Friend
08-20-2020 11:36 AM in
Gear and Gear FitMy Gear S3 frontier (SM R760); Software version: R760XXU2FTD4 (May 2020 update) worked well until last week. Then watch battery started draining suddenly from 89% to zero in a few hours. There are no setting changes (no new watch faces, notifications, etc.). I have power cycled the watch a few times. The battery drain issue remains the same. Any solutions?
Solved! Go to Solution.
- Mute
- Email to a Friend
08-20-2020 11:42 AM in
Gear and Gear FitI think that the next step is to backup the watch using the Galaxy Wearable app and then reset the watch.
- Mute
- Email to a Friend
- Mute
- Email to a Friend
08-20-2020 12:46 PM in
Gear and Gear FitThanks for the suggestion. I have followed your guidance. Let me see how the battery holds up.
- Mute
- Email to a Friend
08-21-2020 03:46 PM in
Gear and Gear FitI'm having the same battery life issues after the most recent update and so are a lot of others. I am also having intermittent connection issues. Hopefully Samsung will take notice and issue an update to correct the problem(s).
- Mute
- Email to a Friend
08-21-2020 04:01 PM in
Gear and Gear FitBacking up and resetting the watch worked for me. It is the second day and the battery holds good so far.
- Mute
- Email to a Friend
01-11-2021 07:46 AM in
Gear and Gear Fit- Mark as New
- Mute
- Email to a Friend
10-08-2020 10:05 PM (Last edited 10-08-2020 10:06 PM ) in
- Mute
- Email to a Friend
10-10-2020 07:18 AM in
Gear and Gear Fit
