Gear S3 frontier sensors don't work
(Topic created: 04-23-2018 05:42 PM)
kairusevon
Gear and Gear Fit
my gear s3 frontier after the last update, stopped working the heart rate meter, wake up gesture, step counter, basically the sensors are not working, how to solve?
SamsungLarryK
Gear and Gear Fit
If you are experiencing this and have completed all possible troubleshooting, can I have the following information via private message? Honestly repairs would be recommended.
Full Model Code:
Serial Number:
IMEI Number (if LTE😞
SamsungCamp
Comet
Gear and Gear Fit
Good afternoon @userrmYKYhWhlr
What troubleshooting steps have you taken so far? Have you tried to perform a factory reset on your watch?
SamsungCamp
Comet
Gear and Gear Fit
@userrmYKYhWhlr
Hello again, just thought I would check back with you and see if you needed any further assistance. If so let us know!
Shariq
Gear and Gear Fit
Hi, I am facing the same issue. I tried factory reset and also dialed *#0*# to check sensors working or not, but they all weren't responding at all.
SamsungCamp
Comet
Gear and Gear Fit
Hello @userRaQ5vHTlJW
And your device is a Gear S3 as well, correct? If so and you have already performed a factory data reset, I would look into getting that watch repaired. To do that you can reach out to us at 1 800 726 7864 or through the Samsung+ application. If you reach out to one of our moderators here in a private message, we can get that scheduled as well.
useroQcw7PJuAO
Gear and Gear Fit
Hi.
Same problem here. After last update sensors don't work in gear s3 frontier.
Reset didn't work.
Too bad I have this watch for only few months and at that price point it's unacceptable..
Vin79
Gear and Gear Fit
My floor counter hasn't worked properly since about a year-and-a-half ago! I was hoping it was software-related but it still doesn't work properly after that long and even new watches launched so must be hardware issue
Mr_Lobby_Silveira_1967
Gear and Gear Fit
Hello guys... I'm following this "Gear S3 frontier sensors do not work" community from the start. I am a victim of the same problem .... The sensors of my S3 also stopped working. I bought my S3 in the US but I live in Brazil. This Samsung policy of not accepting repairs on products purchased outside the country is simply ridiculous. Even when under warranty. It is clear that this problem is a case of "Recal". we need to find legal mechanisms that will force all Samsungs to fix their watches for free !!
Here in Brazil we have the consumer protection code and through it we can fight for our rights as consumers. I do not know the laws of the USA but they should be stricter than those of Brazil for such cases of consumer disrespect as is the case of Samsung.
It's not just stay in prejudice by Samsung error in a software upgrade without the proper tests.
userdW9ppTrY8a
Gear and Gear Fit
Same for me as well. The sensors don't work even i restart the watch. Please give guidance and help on this.
SamsungJace
Gear and Gear Fit
Hello @userdW9ppTrY8a, do you have a Samsung device synced to the watch? If so, can you please provide me with the model number?
