07-02-2018 07:42 PM
Tizen 3.0.0.2
R760
I put the watch to charge and it just keeps switching between charging and not charging, which makes it vibrate non-stop and I'm pretty sure it's wasting battery faster than if I just gave up on charging it and let it die.
I have tried to charge the watch while it's turned off but that just gives me the red blinking lights which means it's not charging. I have tried resetting it but it resets with the "latest update" (R760, tizen 3.0.0.2)
That started happening around 3 to 4 days ago with the update but it would soon fix itself and charge, now I can't even charge for more than 3 seconds uninterrupted.
06-22-2018 05:19 AM
I have exactly the same problem right now. And my Gear S3 is getting hot when is on the charger. Have you received any solution?
05-06-2019 06:50 AM
This is definitely NOT a solution. My device doesn't charge at all, I stopped wearing it for a week and now it doesn't want to charge, I used it for 5 months before and it worked perfectly. What is the solution? I get a flashing red light on charging dock and nothing happens, I tried various cables. Nothing works. I'm baffled and extremely annoyed
05-06-2019 11:30 AM
@userJoMpXpQ0lU Can I please have your full model number and serial number in a private message?
05-24-2019 01:50 AM
05-24-2019 07:46 PM
I am having the same problem. Any suggestions on what has worked to get it working again?
05-25-2019 06:44 AM
@userhCWhXgtT8c Can I please have your full model number and serial number in a private message?
06-15-2019 06:47 PM
I am having the similar problem and talking to the Samsung support they just redirect to the service center which is difficult to locate.
@samsung: If so many people have problem than there is some serious issue.
11-20-2019 01:40 PM
I am also having this issue. I have a Samsung Gear S3 smartwatch that will no longer charge correctly. It doesn't show signs of charging, even after an attempted reboot.
I have tried multiple chargers and cables. It doesn't even respond at all to attempts to wireless charge via my Samsung S10+, even though it used to.
01-04-2020 09:27 PM - edited 01-04-2020 10:25 PM
Same issue on Tizen 4.0.0.4 using the Samsung gear 3s Classic. A continuesly blinking red led, draining the watch battery instead of charging, restart sequence during recharge, no matter how you placed the device in the genuine wireless Samsung charger. I found a working solution by using a more powerfull USB charger such as the Apple iPad one. Problem solved! The genuine charger seems to have issues for what ever reason.
Hope this helps many other new users, cheers,
W
