- Mute
04-20-2017 02:10 PM in
Gear and Gear FitMy Gear S3 Frontier stopped displaying notifications for incoming text messages. They are listed in the messaging app, but the watch does not show new text notifications any more. I have tried to go to settings in the Samsung Gear app, but under manage notifications (where you turn notifications on and off for various apps), "messages" is not listed, so there is not switch to turn messages on or off.
This is not the issue where I don't have a messaging app on my Gear, because the app is still there on the watch, it is just not showing me texts and missing from the Samsung Gear app.
Solved! Go to Solution.
- Mute
01-15-2018 07:33 PM in
Gear and Gear FitHave the s8 plus and gear s3 as well. Don't receive any text messages. If it doesn't get fixed I am returning the watch.
- Mute
04-26-2019 06:52 AM in
Gear and Gear FitI just fixed my issue of no notifications. I went to the "Wearable app" on the phone. It says "Samsung Gear S3" at the top and I see the Batter, Storage and Ram usage. Scroll down and click on Notifications and turn all of them on. I did that and BOOM! Everything started working, now starting the process of elimination.
- Mute
10-16-2020 09:14 PM in
Gear and Gear Fitany solution for this issue? My watch inconsistently shows text messages. need watch to show every notification. frontier watch and S8+
- Mute
05-05-2017 10:51 AM in
Gear and Gear FitI have the same problem. No text (SMS) notification on my watch. It was working fine for abt 3 weeks, now down for 2 weeks.
Phone: S8+
Watch: S3 frontier
- Mute
05-05-2017 12:19 PM in
Gear and Gear FitI am having the same problem
All my notifications are NOT showing up and the amber light does not always glow on......this is happening more often then not, it is VERY ANNOYING. Called Samsung and they suggested to factory reset the watch......did this multiple times tired of hearing the same old fix which does not work. HELP!
Also I set the watch face display on for 1 minute, but it goes off in 15 seconds after I flip my wrist up. If I hit the home button it stays on for 1 minute. Is this the way this is to work?
Does anyone out there no how to fix these problems?
- Mute
11-18-2017 09:33 PM in
Gear and Gear FitDid you find the answer
- Mute
11-25-2017 02:07 PM in
Gear and Gear Fit- Mark as New
- Mute
11-27-2017 09:40 AM in
Gear and Gear FitHave you had a few moments to try any of the suggestions here in this thread? They worked for some others so hopefully they will work for you too. 🙂
- Mute
11-28-2017 09:10 AM in
- Mute
11-30-2017 02:52 AM in
Gear and Gear FitHi there,
I am not sure it has been mentioned elsewhere in the posts. I also had the notification problem. I have a Xiaomi Mi 5. I had to set "Manage apps' battery usage" to "No restriction" for Samsung Gear and apps from which you want notifications (for instance whatsapp), and allow Autostart for Gear S Plugin, Samsung Gear, Samsung Accessory Service and apps from which you want notifications. Since then I get the notifications on my S3. I don't know if there is an equivalent in Android for non MIUI devices (the layer developed by Xiaomi for their Android based devices). Also, it could be that I don't need all of that, but it works now.
